Alkaline Water
Azul
Why Alkaline Water
Because alkaline water has a higher pH level than plain tap water, proponents say that it can neutralize acid in your bloodstream. Some say that alkaline water can help prevent disease, such as cancer and heart disease. However, more research is needed to verify these claims.
Some studies also suggest that alkaline water might help slow bone loss, but further investigation is needed to determine if this influences overall bone mineral density and if the benefit is maintained over the long term.
With zero additives and zero pH altering, AZÜl achieves the perfect 9.5 pH as Mother Nature intended. The alkalinity and mineral content is familiar to your body and perfect for your body’s hydration and health. AZÜl is the only choice that matches nature with science perfectly. Mother Nature’s 9.5 pH.
Alkaline ionized water is used for drinking and cooking, and provides users with several important health benefits:
  • ALKALIZING: restores pH balance by reducing acidity levels in the body
  • ANTIOXIDANT: helps to neutralize free radicals that can cause cellular and DNA damage
  • SUPER-HYDRATING: smaller water cluster size allows water to penetrate cells more easily
  • MINERAL RICH: contains higher concentrations of alkaline minerals such as calcium, magnesium, and potassium which are vital to human health
  • OXYGEN RICH: increases the amount of dissolved oxygen in the blood
  • DETOXIFYING: eliminates mucus build-up on colon walls, thus improving the body’s ability to absorb important nutrients
  • CLEANSING: contributes to flushing out acidic waste and toxins that have accumulated in the body over time
  • ENERGIZING: negatively charged hydroxyl ions contribute to increased energy, mental clarity, and overall alertness
  • WEIGHT CONTROL: reduces the body’s need for fatty tissues which protect vital organs from acidity by storing acidic waste in less critical parts of the body
  • CLEAN WATER: pre-filtration cartridge inside the ionizer removes chlorine and other common pollutants present in tap water
  • REMOVES PESTICIDES: strong alkaline water with a pH over 10.5 helps to remove pesticides from fresh fruits and vegetables
